I have a problem with the software center in Ubuntu Precise. Each time I open it, the software center freezes and I cannot work anymore with it (Ubuntu itself continue working without problem, its only the software center)
I usually to work with the terminal, but I'd like to know if there is any solution for this 'freezing' problem
Anwar
  • 77,855
Open a terminal and run this command below, Check by reopening Software center:
sudo update-software-center
This will regenerate cache needed by software center.
Hope this helps.
Anwar
  • 77,855
