Have been using apt-fast for a while now and really liking it. In case you don't know it is useful to speed up apt-get. However, I have a few questions regarding apt-fast:
  1. I would like to make any call to apt-get run apt-fast. I'm assuming I can put a script called "apt-get" in my ~/bin folder that executes apt-fast... so maybe I'm answering my own question on this first one.
    Would a script like this work?
    #!/bin/bash
    exec apt-fast $@
    exit 0
  2. apt-fast does not seem to speed up the very thing I wish it sped up most - apt-get update
    I would like apt-fast to make apt-get update run faster. Is this possible?
Anwar
  • 77,855
You can create an alias for apt-get in your home directory. To do so, follow these:
  1. Open a terminal and do this command:
    touch ~/.bash_aliases; gedit ~/.bash_aliases
  2. In the new opened file, type these and save and exit.
    alias apt-get='apt-fast'
Then, whenever you run apt-get, apt-fast will run instead
For more info, see this page
Anwar
  • 77,855
apt-fast does not make 'apt-get update' faster. If you'll check the code, e.g.
vi /usr/bin/apt-fast
You'll find the line:
if echo "$@" | grep -q "upgrade\|install\|dist-upgrade"; then
else
apt-get "@"
Which means that apt-fast does nothing in all other commands except in upgrade, install, and dist-upgrade.
Majal
  • 8,249
