Is it possible to restore a single file from the .tar backup? I don't want to restore total backup. I just want to restore one single file from the backup.
Asked
Active
Viewed 2.4e+01k times
181
1. Using the Command-line tar
Yes, just give the full stored path of the file after the tarball name.
Example: suppose you want file etc/apt/sources.list from etc.tar:
tar -xf etc.tar etc/apt/sources.list
Will extract sources.list and create directories etc/apt under the current directory.
- You can use the
-tlisting option instead of-x, maybe along with grep, to find the path of the file you want - You can also extract a single directory
- tar has other options like
--wildcards, etc. for more advanced partial extraction scenarios; seeman tar
2. Extract it with the Archive Manager
Open the tar in Archive Manager from Nautilus, go down into the folder hierarchy to find the file you need, and extract it.
- On a server or command-line system, use a text-based file manager such as Midnight Commander (
mc) to accomplish the same.
3. Using Nautilus/Archive-Mounter
Right-click the tar in Nautilus, and select Open with ArchiveMounter.
The tar will now appear similar to a removable drive on the left, and you can explore/navigate it like a normal drive and drag/copy/paste any file(s) you need to any destination.
