97
I've installed Ubuntu 12.04 32-bit on my machine. But when I switch on the computer, I get command line:
Ubuntu 12.04 LTS COMP-1245 tty1
And it prompts for username and password. Once I provide my username and password, it authenticates login and then displays a link to documentation.
Now, how can I start GUI? I'm stuck at command line.
Kulfy
  • 18,154
If you tried the command startx, but the error command not found was returned, then to install a graphical desktop, in case it is not installed, you would type this:
sudo apt-get install ubuntu-desktop
Mitch
  • 109,787
32
Try to use startx in your tty , if it does not work on one terminal try Ctrl+Alt+F1 to F6 in order to switch a new tty
Kulfy
  • 18,154
11
I have had the same problem. The solution is to install X.org and the Ubuntu Desktop. Also, don't forget the build-essential packages:
You might have to install X.org separately, but also take advantage of this command line because (for my situation) Ubuntu kept trying to use my display port.
David
  • 3,487
paxsonsa
  • 119
