I had a company computer(ubuntu 12.04LTS) taken home. My home use DSL and my company use LAN to connect to internet. The computer works well in my company, but I have to config it after taken home. I used pppoeconf to config the DSL successfully at home. and use pon dsl-provider to connect to internet. But after I take the computer back to company, I had to change back to LAN. After Google it, I modified the file /etc/network/interfaces
auto lo
iface lo inet loopback
auto dsl-provider
iface dsl-provider inet ppp
pre-up /sbin/ifconfig eth0 up # line maintained by pppoeconf
provider dsl-provider
auto eth0
iface eth0 inet manual
to
auto lo
#auto dsl-provider
#iface dsl-provider inet ppp
#pre-up /sbin/ifconfig eth0 up # line maintained by pppoeconf
#provider dsl-provider
#auto eth0
#iface eth0 inet manual
but this does not work: When reboot the computer, the network-manager shows wired network already connected, but not show the "Wired connection 1". ifconfig shows eth0 have ip address 192.168.1.108, but cannot connect to internet. I tried to add Wired Connection 1 manually, choose the MAC of eth0 in Device MAC address, and save. It shows: Connection add failed , Connecttion not visible or not available. (I thought it should work here. DHCP/Manual ip addresses both works well several day before.)
I had several other tries: I changed the /etc/network/interfaces file to
auto lo
#auto dsl-provider
auto eth0
still not work. and changed to some static ip address not work, either. I think that pppoeconf make some change to the network-manager configuration or networking config, so that after stopped pppd, the network-manager does not work. Please give me some advices, thanks!
cmal
  • 121
Same problem with you.
Those guys' tries may help you solve this problem:
http://ubuntuforums.org/showthread.php?p=12111017
Eliah Kagan
  • 119,640
i have the same problem i solved it like this
Edit /etc/NetworkManager/nm-system-settings.conf file by using
sudo gedit /etc/NetworkManager/nm-system-settings.conf
find and change “managed=true” (without quotes).
Edit /etc/network/interfaces,
sudo gedit /etc/network/interfaces change its content to:
auto lo
Delete /etc/resolv.conf by this command:
sudo rm -rf /etc/resolv.conf
Now,restart machine or restart the network-manager by this command:
sudo /etc/init.d/network-manager restart
Add DSL connection to network-manager and make it auto-connect at login.
Right click on network-manager icon and select “edit connections”
Delete useless connection.In DSL tab,click Add and then input your Username and Password.
Remember check the “Available to all users” to prevent keyring locked problem.
SUGGESTION i will suggest to keep using pppoeconf command because by using network manager MTU problem can give you headache, which causes slow internet and most of the sites won't load. just have a look at this thread
H S
  • 247
