Before I upgraded to Maverick, .swf files used to have a thumbnail in Nautilus. However, Nautilus doesn't generate thumbnails for them anymore, even after removing ~/.thumbnails/, which most likely indicates that a package is missing.
How do I get Nautilus to generate thumbnails for .swf files?
EDIT: I've added a bounty, as I believe this question might still be answered...
htorque
  • 66,086
The thumbnails were made with libswfdec (i.e. /usr/bin/swfdec-thumbnailer from the package swfdec-gnome), which was removed in Ubuntu 10.10 ("maverick"). The libswfdec author stopped development because there are already 2 other open source projects working on implementing an SWF player: gnash (which is included in Ubuntu) & lightspark (which is new and not included yet). I am not sure if there exists a thumbnailer that uses gnash...
JanC
  • 19,802
There is a way of getting this done explained in the Floorplanner Tech Blog. To compile dump-gnash on a fresh Maverick you'll need
sudo apt-get install gcc libboost-dev libboost-thread-dev libagg-dev libsdl1.2-dev libcairo-dev libgstreamer0.10-dev libatk1.0-dev libglib2.0-dev libpango1.0-dev libgtk2.0-dev libgtkglext1-dev libgl1-mesa-dev libgif-dev libjpeg-dev libgstreamer-plugins-base0.10-dev libspeex-dev libcurl-dev
And then you just follow the steps. This will take a long time.
NOTE: For Step 7 use the following script instead:
if [[ $3 ]]; then
    raw="$(mktemp)"
    dump-gnash $2 -P "FlashVars=url=file://$1" -D "$raw" --max-advances 1 -j 500 -k 500
    tail -c 1MB "$raw" | convert -size 500x500 -depth 8 rgba:- -separate -swap 0,2 -combine -trim png:"$3"
    trap "rm $raw" EXIT
else
    echo "Insufficient arguments (expected 3 arguments)"
    exit 1
fi
Once you have the final script running you just hook it into gconf-editor
gconftool-2 -s "/desktop/gnome/thumbnailers/application@swf" -t string "/usr/bin/swfthumbnailer.sh %s %i %o"
gconftool-2 -s "/desktop/gnome/thumbnailers/application@swf/enable" -t boolean 'true'
gconftool-2 -s "/desktop/gnome/thumbnailers/application@x-swf" -t string "/usr/bin/swfthumbnailer.sh %s %i %o"
gconftool-2 -s "/desktop/gnome/thumbnailers/application@x-swf/enable" -t boolean 'true'
gconftool-2 -s "/desktop/gnome/thumbnailers/application@x-shockwave-flash/command" -t string "/usr/bin/swfthumbnailer.sh %s %i %o"
gconftool-2 -s "/desktop/gnome/thumbnailers/application@x-shockwave-flash/enable" -t boolean 'true'
Then restart (or restart gnome-settings-daemon), and you've got swf thumbs!
P.S.: This is a huge hack. A better way to do this would be vastly appreciated.
Isaiah
  • 60,750
MrMartin
  • 248
The closest thing I've been able to find is perhaps using ffmmpegthumbnailer to create thumbnails for you and that should handle the .swf files.
This blog post has the instructions.
Zanna
  • 72,312
Jorge Castro
  • 73,717
Simplest answer should simply be to install swfdec-gnome, but the Lucid version. Not hard to do, just go to http://packages.ubuntu.com/da/lucid/swfdec-gnome and select your architecture. Then just do what you did previously to make it work; it seems to just randomly kick in for me, as I recall. Maybe after a log out/restart. Good luck to you.
