Is there any available IDE for Python GTK 3, i.e. An IDE which give the programmer an auto complete feature with method Description etc.?
pomsky
  • 70,557
Andrew
  • 27
I recommend using VSCode with the Python extension installed. You can install VSCode by downloading the .deb installer and running in a terminal:
sudo apt install /path/to/vscode.deb
Then, run VSCode, hit Ctrl+P to launch VSCode Quick Open, paste the following and hit Enter to install the Python extension:
ext install ms-python.python
Another Python IDE I am using and recommend is Jupyter Lab. If you are using the Anaconda Python Distribution you can install it by running:
conda install -c conda-forge jupyterlab
If not, you can install it using pip:
pip install jupyterlab
Try using IDLE 3
sudo apt-get install idle3 idle-python3.2
another one bypython
You might want to take a look at available tools
Ubuntu community Wiki
Power Users Programming
atenz
  • 12,858
Also I like geney, it is in software center and is beginner friendly. Also there is codeblocks which is pretty good. And I saw a new one called spider the other day whitch has got some very good reviews. Python is well supported in Ubuntu so have a search in software center theres about 20 IDE s with python support just play around till you find one you like...
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
Try Anjuta IDE if you want a graphical designer
sudo apt-get install anjuta anjuta-extras
Or try PyCharm jetbrains.com/pycharm if you want a smart full-featured IDE ;-)
