I have a set of packages that I wish to install along-side the minibase variant in debootstrap. I'm having the hardest time figuring out how to customize variants so that more than just the base is installed in a chroot when debootstrap is run. Any way to achieve this?
Asked
Active
Viewed 9,811 times
10
It's pretty easy to add your own variant with additional custom packages to debootstrap.
The debootstrap configuration/runtime scripts are located in /usr/share/debootstrap/scripts. Let's create an allmybase variant which includes everything in minbase along with the packages htop and traceroute.
Open
/usr/share/debootstrap/scripts/precisein your editor.- Note that this, along with many Ubuntu releases, is a symbolic link to
/usr/share/debootstrap/scripts/gutsy; if you want to affect only a specific release, break the link and make it a copy of the gutsy script instead.
Around line 22, find the line beginning with
variantsand add your custom variant at the end:variants - buildd fakechroot minbase allmybase
Find the
work_out_debs()function around line 34, and look at the default settings for thebasevariable for your "base" variant (here,minbase):elif doing_variant fakechroot || doing_variant minbase; then base="apt"Append your own variant with custom packages at the end of the function:
elif doing_variant allmybase; then base="apt htop traceroute"Save, exit, and test it out with the
--print-debs"simulation" flag, e.g.sudo debootstrap --print-debs --variant=allmybase precise /tmp/prec-chroot
- In this example, the output will show that the
htopandtraceroutepackages will be included in the allmybase chroot.
ish
- 141,990
