Ok so I tried for the first time to use PGP keys for email encryption in Evolution. I followed some instructions online, created a key, but coz I encountered some problems I decided to delete the key and restart the proces. (This fact is probably irrelevant, because I got similar errors when doing it.)
Now I have no key and I go to Remote: Sync and publish keys. Firstly it says that there are 6 keys selected for synchronisation. Why? I do have some passwords saved in here, will it sync those too??
And last, when I click sync I first get two errors:
Couldn't retrieve keys from server: pool.sks-keyservers.net
Couldn't communicate with server 'pool.sks-keyservers.net': Internal Server Error
and
Couldn't retrieve keys from server: keyserver.ubuntu.com:11371
Couldn't communicate with server 'keyserver.ubuntu.com:11371': Internal Server Error
Than the progress stops and no progress is made, it just says:
Synchronising keys... Exporting data
Any help?
I had the same problem. I fixed it by:
  1. Remove all existing keyservers from the Sync box (by default hkp://keyserver.ubuntu.com:11371, hkp://pool.sks-keyservers.net, and ldap://keyserver.pgp.com).
  2. Add them over again (keeping the same settings).
  3. Press Sync.
Don't know why this works, but it does.
Eliah Kagan
  • 119,640
Another workaround is to go directly to https://keyserver.ubuntu.com/ and submit the ASCII-armored version of your key.
You can generate it like this:
gpg --armor --export $your.email.address@foo.com
One of the following approaches worked for me, I'm not sure if the first will fix it but I will certainly encourage for the 2 approach.
This anwer was inspired by both @Pranesh-Prakash and @ConorSheehan1 answers.
  1. Using Password & Keys GUI app, go to Preferences, and activate the checkbox for Automatically synchronize modified keys with key servers. Retry sync
If the synchronization fails then try this:
  1. Using Password & Keys GUI application, go to Preferences.
    • In the Keyservers section, add a new one using the Add keyserver button
      • Select HTTPS as the Key Server Type.
      • Add keyserver.ubuntu.com (no protocol, no port) as HOST
    • (My current version of Password&Keys doesn't update automatically to reflect the changes so I have to close Preferences and re-open it for the next step)
    • In the Key Synchronization section, from the Publish keys to drop down list select the new keyserver you just added.
    • Close preferences and try sync
Karmavil
  • 101
-1
Try this solution from ubuntuforums. http://ubuntuforums.org/showthread.php?t=1726418
gpg --gen-key --enable-dsa2
Hope this helps!
