26
Possible Duplicate:
How do I use sudo in my script without needing a password?
I want to run a bash script as root with no password prompt.
I tried visudo with no luck(your_username ALL=(ALL) NOPASSWD: /path/to/your/script).
It seems to me the only way out there, is there any other?
Vromoth
  • 731
There is a very neat trick in every Linux which will allow you to do so. It is called the SetUI bit.
Keep in mind that you will need to have the permissions locked down tight in this file for this to be secure.
Make the file owned by root and group root:
sudo chown root.root <my script>
Now set the SetUID bit, make it executable for all and writable only by root:
sudo chmod 4755 <my script>
Keep in mind if this script will allow any input or editing of files, this will also be done as root.
The SetUID bit makes a script or binary always run as the owner of the file/binary, an example of such a binary is 'passwd'.
There is a solution using sudoers here is an example you could use. Add these two lines at the end of your sudoers file. You can use visudo to edit the sudoers file.
Cmnd_Alias        CMDS = /path/to/your/script
<username>  ALL=NOPASSWD: CMDS
Now just place sudo in front of your script and it should run without asking for a password.
wilson
  • 13
KDrag
  • 829
