I have tried to make google chrome run as root using this tutorial but now simply Google Chrome won't start.
If I try from terminal with google-chrome I get:
root@ubuntu:~# google-chrome
Segmentation fault (core dumped)
If I try to uninstall from the software center, it simply hangs when I click on installed software. I tried apt-get purge but with no success. What do you suggest?
user unknown
  • 6,892
Run the following command as root: apt-get purge google-chrome-stable.
Eric Carvalho
  • 55,453
Go to /usr/bin, edit google-chrome. I did it with Kate.
At the end of exec -a "$0" "$HERE/chrome" "$@", add --user-data-dir, so it looks like this: exec -a "$0" "$HERE/chrome" "$@" --user-data-dir.
Eric Carvalho
  • 55,453
Kill chrome in system monitor and then try removing it.
Arup Roy Chowdhury
  • 1,580
You can kill Chrome from the System Monitor: Launch it from the Unity ta sk bar (it's just called "System Monitor") or launch it from the terminal with gnome-system-monitor -- you'll see all running processes under the "Processes" tab. You might have a few "Chrome" processes running (I had four just now) -- select the processes called chrome and use the "End Process" button to kill them.
vusan
  • 477
Amanda
  • 9,723
