I am currently running Ubuntu 12.04 LTS, installed via Wubi on a Windows 7 machine. My HDD is 1 TB. When I installed via Wubi I used the maximum 30 GB installation size. Since then, I have decided I want to make Ubuntu my primary operating system. So my question is, how do I increase the size of /home without losing my data?
While I'm not a total noob to Linux I am by no means an advanced user.
I downloaded ubuntu-12.04-desktop-amd64.iso from Ubuntu.com, made a bootable disk out of my USB drive, and started up the "trial version" of Ubuntu. I ran the installer until I got to this screen
I didn't want to install in Windows - that's what I already have through wubi and what I'm trying to fix. Nor do I want to replace Windows because there are still a few tasks here and there that I still need it to run. So I clicked the "Something else" option. I was greeted with this screen
I know virtually nothing about partitions because I've never had to mess with them before. So I clicked "Install now" and prayed that it would work. Instead, I got this error message
Like I said in my first edit, I'm by no means an advanced user, but you seem to know quite a bit about partitions, so can you help me?
Mitch
  • 109,787
Matt
You could boot a Knoppix DVD and resize the NTFS partition Ubuntu is stored in a file on. After resizing it, you can create a ext4 partition in the free space. Now you can boot Ubuntu and copy all your /home to the new partition. You would now be able to delete /home on the old Wubi partition, add the new partition in /etc/fstab, and you would have migrated your /home to a real partition with more space.
If you do not want to switch to real partitions (which are IMHO better, since they would give you superior performance), you can extend your Wubi parition size: Is it possible to extend the disk space available to a wubi install?
