Command (in terminal): leafpad
Result: Leafpad without root rights working fine.
What did I do to cause the error? Maybe I accidentally run
sudo leafpad
Now I am having problems... Neither kdesudo nor gksu are functional.
Command:
kdesudo leafpad
Error:
kdesudo(2831) KDESu::KDESuPrivate::KCookie::getXCookie: No X authentication info set for display  ":0"
No protocol specified
leafpad: Cannot open display:
Command:
gksu leafpad
Error:
Gkr-Message: secret service operation failed: The name org.freedesktop.secrets was not provided by any .service files
What must I do to fix the error?
Run this command in the Konsole/Terminal:
sudo rm ~/.Xauthority /root/.Xauthority
That should fix the problem, as new .Xauthority files will be created as needed.
In the future, when running graphical apps as root, you can avoid creating this and other problems by using a graphical frontend like kdesudo (or gksu/gksudo) rather than invoking sudo directly.
Eliah Kagan
  • 119,640
The error I had was I think very similar:
I installed gnome-keyring Install gnome-keyring and its dependencies and my problem was solved. My best guess is that the run of apt-get autoremove has caused this error in the first place. (I do not recommend to run this command).
acidb1
