10
I am running the Ubuntu 12.04 server edition (static LAN IP) and was tying to install SABnzbdplus using the apt as per instructions here: Ubuntu PPA Repository
Installation has gone smoothly and the server downloads etc no problem! The problem is that I have edited /etc/default/sabnzbdplus as the directions provided to:
# This file is sourced by /etc/init.d/sabnzbdplus
# When SABnzbd+ is started using the init script, the
# --daemon option is always used, and the program is
# started under the account of $USER, as set below.
# Each setting is marked either "required" or "optional";
# leaving any required setting unconfigured will cause
# the service to not start.
# [required] user or uid of account to run the program as:
USER=omar
# [optional] full path to the configuration file of your choice;
#            otherwise, the default location (in $USER's home
#            directory) is used:
CONFIG=
# [optional] hostname/ip and port number to listen on:
HOST=0.0.0.0
PORT=8080
# [optional] extra command line options, if any:
EXTRAOPTS=
My (omar) runlevel is N 2.
Not quite sure what to do because executing: /etc/init.d/sabnzbdplus Works fine and error free.
Not sure what to do here. Advice and assistance would be greatly appreciated!
Thanks,
Jorge Castro
  • 73,717
Omar Mir
  • 313
The guide forgot
sudo update-rc.d sabnzbdplus defaults
This command will add the links at the correct runlevels so that sabnzbdplus starts and stops when booting, rebooting, shutting down, etc.
edit: if you get the message that those links are already in place have a look at this question
edit2: or this one
