-1
Possible Duplicate:
How to install a .tar.gz file?
So I want to install the zathura package:
http://packages.ubuntu.com/natty/zathura
Unfortunately it isn't as easy as sudo apt-get install and my resident linux geek has gone to sleep.
Following the link above it is possible to find some .tar.gz archives, one of which (zathura_0.0.8.5.orig.tar.gz) actually includes a README and a make file. Nevertheless whoever wrote those assumes a basic level of competence that I do not have. In particular I have no idea how to check whether I meet the stated requirements, and what to do if I do not. (running make install produces a bunch of errors, so I assume I don't have the required dependencies.)
Still a beginner so I usually need step by step instructions to install anything.
In a response to comments below it is important I am running Ubuntu 10.04 LTS - the Lucid Lynx. Apparently the package in question is incorporated in the "Ubuntu Software Centre" for newer versions of Ubuntu.
I also appreciate this post is getting to localized. Nevertheless I just want to thank everyone who answered/commented. Between this discussion and the other post (How to install a .tar.gz file?) I am close to having worked out how to compile the package from source.
My apologies for answering my own question as well as the fact that it was probably to localized.
The one bit of information I needed and wasn't able to find on that other post (How to install a .tar.gz file?), which might be of general interest, is that when a README file in a .tar.gz file containing the source code for some package lists it's pre-requisites/dependencies you need the developer version of those packages. For example, I needed libpoppler-glib-dev (in Synaptic) rather than libpoppler-glib4 which I already had. Threw me off.
Once I had the right packages it was as easy as running make and then sudo make install (or checkinstall) while in the extracted folder containing the package.
Install the package using Ubuntu Software Center or Synaptic (this will install the prebuilt application)
Jazz
  • 2,755
