I have three Linux and two Windows systems on one computer.
After updating the kernel on one (archlinux) and running update-grub on the default (BIOS) boot disk (Xubuntu 12.04), the boot menu does not report the archlinux system.
After running boot-repair, I cannot boot the archlinux system by selecting it as the boot disk in BIOS because it now uses the boot configuration on the Xubuntu system instead of booting directly from its disk.
I really need to be able to boot the archlinux system, how can I do this?
Note: Bugs filed and notices made on this.
jdthood
  • 12,625
The 10.04 Ubuntu and the 12.04 Xubuntu grub2 failed for different reasons, so I used the third Linux system to solve the problem, see os-prober fails to identify a linux system so I need to write a custom grub2 menu entry as a workaround, how? for details.
Lorenz Keel
  • 9,511
Try it with Super GRUB 2 disk.
You can download it from here
Then install it in a usb using Unetbootin Now you could restart your system and make sure it is set in the boot option menu.
Try this:
sudo nano /etc/grub.d/09_custom_arch
Put the following text in the file:
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
menuentry "Arch Linux" {
insmod ext2
set root=(hd0,1)
linux /vmlinuz26  root=/dev/sda2 ro quiet rootdelay=1
initrd /kernel26.img
Be sure to modify the (hd0,1) and sda2 to reflect the actual partition that contains Arch Linux in your particular setup.
Now, run:
sudo update-grub
This should at the very least steer you in the correct direction.
Credits
SirCharlo
  • 40,096
I found a little app for linux, that has helped me greatly in getting my system to run correctly. (Windows dedicated drive + Linux also on a dedicated drive,) try this program: "Grub Customizer" after using the "Boot-Repair" (either disk, or installed via a PPA,) to manage the boot options.
I install each OS on it's own DRIVE (either HDD or USB,) and use the "F9" feature in my BIOS as I start to select which drive I want to load.
Using these two (2) programs together (Boot-Repair first, then Grub Customizer second,) has fixed my annoying troubles so that now when I start my computer, it starts as it is supposed to do. (Internal SSD first, has Windows 7 on it, F9 at boot to select other OS if I need.)
Hope this helps, I know the feeling of not having what you want, when it pertains to a running system. Before I go, one other very handy tool to use is: "TWEAK TOOL" not only to change fonts, resize background photo's for the desktop, but many useful hidden settings revealed with easy GUI buttons to select intended options.
Best of luck!
