NTOP is a network monitor.
It has a web interface for viewing statistics.
I installed it via sudo apt-get install ntop on Ubuntu 2012.04, the daemon got started at the end of the install, without me doing anything special.
QUESTION: How to access the web interface?
http://localhost:4242 says Unable to connect.
I tried stopping the daemon and launching it in various ways:
sudo ntop -P /etc/ntop -W4242 -d
sudo ntop -P /var/lib/ntop/ -W4242 -d
But still Unable to connect.
Nicolas Raoul
  • 11,921
You can view and configure it through http://hostname:3000/ or http://127.0.0.1:3000/
ntop focuses on :
  • Traffic measurement
  • Traffic monitoring
  • Network optimization and planning
  • Detection of network security violations
You can also go through the documentation and Man Pages for optimum usage.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
atenz
  • 12,858
There are two ways to access the web-gui for NTOP.
-w --> This uses an unencrypted connection (the default). Port 3000 unless overridden.
-W --> Uses SSL encryption.
Examples:
  1. Default Setup
    sudo ntop -d
    This would default to an unencrypted ntop service running on port 3000. To connect you would type http://[IP_ADDRESS_OF_SYSTEM]:3000 into the address bar of a web browser.
  2. Encrypted Setup
    sudo ntop -W 8080 -d
This results in an encrypted ntop service running on port 8080. To connect you would need to type https://[IP_ADDRESS_OF_SYSTEM]:8080 into the address bar of a web browser.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Jeremy
  • 51
