I used to have my own shortcut keys to minify all the CSS and JS files for my websites after I saved the original larger version of the file. But that was on Ubuntu 11.04 and now I cannot figure out for the life of me to get the Alt + Shift + E to run my command. Anyone know what files to edit or what options screens to go through to complete this? Thanks in advance!
Asked
Active
Viewed 1.0k times
Like carnendil has mentioned. There is a tab entitled, "Shortcuts" in the "keyboard" option from "all settings". Down to the left, there is the option, "Custom Shortcuts". Use (+) and (-) to add or remove shortcuts!
For instance, to add the shortcut for (System monitor), press (+), a small prompt will ask you to enter the short cut name and command,
Command: gnome-system-monitor
After pressing apply, the short cut will be disabled. Click on the word (disable) and press on the keys combination for your shortcut.
Frost Griffin
- 301
I might be wrong, but I think you are looking for Keyboard in System Configuration. There you'll find a tab named Shortcuts.
carnendil
- 5,529
