I'm trying to set up a freshly installed Ubuntu (12.04) server, but I can't get PHP files running through php-fpm. No matter what I do, I always get a "Access denied." page (plain text, not html or anything).
Installed packages:
nginx
nginx-common
nginx-full
php5
php5-cli
php5-common
php5-fpm
Configuration details:
PHP-FPM:
user = www-data
group = www-data
listen = /var/run/php5-fpm.sock
Nginx:
user www-data;
worker_processes 3;
events { worker_connections 1024; }
Default/test domain:
server {
listen 80;
server_name localhost;
root /extra/htdocs/default;
index index.html index.php
access_log /extra/logs/default/access.log;
error_log /extra/logs/default/error.log;
location / {
try_files $uri $uri/ /index.html;
location ~ \.php
fastcgi_split_path_info ^(.+\.php)(/.+)$;
include fastcgi_params;
fastcgi_index index.php;
fastcgi_pass unix:/var/run/php5-fpm.sock;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param PATH_TRANSLATED $document_root$fastcgi_path_info;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
/extra/htdocs/default/index.php:
<?php
phpinfo();
Everything else is default. Both the Nginx and php-fpm logs show no errors. Yet when I load http://<server-ip>/index.php I get the "Access denied" page.
Troubleshooting:
- The index.html file works just fine. Therefore it must be either php-fpm, or the fastcgi binding between Nginx and php-fpm.
- I've set the ownership (both user and group) of the entire
/extradirectory towww-data, and ownership to 777, just to be sure (I'll tone it down once it works of course). So it's certainly not a permissions issue - It's not the security.limit_extensions issue that I see a lot: by default that is set to .php, which is exactly what I'm requesting. I've explicitly set it to
.php .html, with the same result.
I'm really getting tired of this, I've installed this setup twice already (albeit on OSX machines), and everything worked flawlessly. Is there anything I'm overlooking?
The log contents:
The Nginx error log is empty.
Nginx access log (removed ip):
<ip> - - [17/Jul/2012:11:21:25 +0200] "GET /favicon.ico HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_4) AppleWebKit/536.11 (KHTML, like Gecko) Chrome/20.0.1132.57 Safari/536.11"
<ip> - - [17/Jul/2012:11:21:28 +0200] "GET /index.php HTTP/1.1" 403 46 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_4) AppleWebKit/536.11 (KHTML, like Gecko) Chrome/20.0.1132.57 Safari/536.11"
<ip> - - [17/Jul/2012:11:21:34 +0200] "-" 400 0 "-" "-"
php-fpm log:
[17-Jul-2012 10:44:14] NOTICE: fpm is running, pid 4969
[17-Jul-2012 10:44:14] NOTICE: ready to handle connections
