332
I want something similar to "preview" in macs. For example: I want an image editor that ONLY does simple adjustments like increase/decrease contrast, saturation, exposure, color tinting.... rotate, flip vertically, flip horizontally, make black and white, change size or format, crop.
THATS IT. I know gimp can do all those things but its a bit overkill. I just want to right click an image, open it with this magical program i just described, do a few quick adjustments, and then save and exit. Nothing really fancy.
Anyone know of anything like this? Btw I am using ubuntu 12.04 :) It rocks and I am glad I switched from mac, i just need to replace this one piece of software.
Jorge Castro
  • 73,717
mandy
  • 3,341
8 Answers8
262
Pinta
A very simple image editor.
Pinta is a drawing/editing program modeled on Paint.NET. Its goal is to provide a simplified alternative to the GIMP for casual users.
Features
Its features include:
  • Adjustments (Auto level, Black and White, Sepia, …)
  • Effects (Motion blur, Glow, Warp, …)
  • Multiple layers
  • Unlimited undo/redo
  • Drawing tools (Paintbrush, Pencil, Shapes, …)
See the website for the full list.
Another feature of Pinta is full history saving. Say you want to continue a work later on, keeping all the layers intact (so that you can add/remove them later on), you can save the file in .ora format. It preserves every edit you have made so that you can reverse the changes.
Installation
For Ubuntu versions up to 12.04 you need to add a PPA to install this and keep it updated:
  • Ubuntu 10.10, 11.04 & 11.10
     sudo add-apt-repository ppa:pinta-maintainers/pinta-stable/ubuntu
     sudo apt-get update
  • Ubuntu 12.04
     sudo apt-get update
Installing via the Terminal
Run this command:
sudo apt-get install pinta
Installing via the Ubuntu Software Center
  • Launch the Ubuntu Software Center
  • Search for "pinta"
  • Click the 'Install' button
Once it is installed you can now use Pinta. Navigate to: Menu > Graphics > Pinta
Screenshots
screenshot including "Adjustments" menu
screenshot including "Effects" menu
sample image with drawings on top of it
taper
  • 228
Ashu
  • 9,642
77
Shotwell has a single photo view that allows you to do most if not all of what you're asking. Shotwell, of course, has the advantage that it's included by default in modern Ubuntu so there's nothing to install.
To access the Shotwell viewer without separately launching the main Shotwell app, right click the photo and from the Open With menu select Shotwell Photo Viewer:
Right click, Open With -> Shotwell Photo Viewer
(You can make the Shotwell viewer the default program to open photos by selecting Properties from the right click menu and messing around in the Open With tab there.)
From the Shotwell viewer, you can rotate, crop, manipulate color levels, etc., and simply save the file when you're done. You can see the tools at the bottom of the window here:
Whereas usually Shotwell is nondestructive (in the sense that any manipulations you perform on photos are only saved to a photo file if you export it), hitting save from the viewer does indeed write the changes to the file.
Full disclosure: I work at Yorba, though not on Shotwell.
αғsнιη
  • 36,350
chazomaticus
  • 1,263
41
GThumb
GThumb is a really nice image viewer with basic editing tools such as:
  • Crop
  • Rotate
  • Equalize
  • Change Contrast
  • Change Focus
  • Change Colors
  • Apply basic effects (Grayscale, Negative, etc.)
Installation:
sudo apt-get install -y gthumb
Screenshots:
Screenshot 1 Screenshot 2
Click to view them in high quality
brasofilo
  • 192
Sheharyar
  • 1,268
22
You might like gThumb. It can do all that you mentioned and little else.
xjonquilx
  • 1,497
  • 19
18
I would try Pinta (it's in the repos), as it is simple and has all the necessary basic adjustments to do with contrast, brightness, etc, and even has layers functionality. It is ideal for a quick crop, resize or red eye correction. The version in the repos is 1.1, but you can use a ppa from the developers if you want to have a more recent version-see the notes on the site about whether to use the ppa or not. However, the default version is fine and is very useful for those quick corrections. As you can see in the screenshot below the interface is easy to navigate and simple and intuitive to use.
I was just looking for something similar. I've found some candidates on Wikipedia, and I'm about to check some out.
A few I've found so far are: Shotwell, fotoxx, and the already-mentioned gthumb. I don't know yet which ones are in the Ubuntu repository.
EDIT: I have been using Shotwell now for a long time, and find that it does most of what I want, very quickly and easily. When it doesn't, it can directly open a full editor such as GIMP quickly to do the job instead.
I especially like that it can easily resize images, something I do a lot.
Marty Fried
  • 18,944
Kolourpaint - simple and light, less than 7MB. Similar to MS Paint. You can download directly from AppCenter enter image description here
sosnus
  • 139
I include MTPaint in my options as it will open suspect .bmp files from my Chinese Digital Storage Oscilloscope. It is very compact and very close to what Paint users would expect.
If you have kids under 5, start them on Tuxpaint.
mckenzm
  • 383
