I have filled my disk but can see games in /usr that I could delete but can't see how to do it. I am not a computer buff and have no idea what a terminal is.
- 119,640
- 37
Normally, it is advised to refrain from manipulating files in system folders by hand. Open Software Center, look for the games you want to get rid of and hit Remove.
I do understand you are queasy about the terminal, but if no commands are mistyped, this will be quite easy. Wait for the something@somewhere ~$ prompt before typing the next command. Note that something and somewhere in the prompt may be different words--do not worry.
The default games installed are gnome-games. To remove them, open "Terminal" by searching it in the launcher, and type sudo apt-get remove gnome-games
It will prompt for a password, which will not be shown when typed(Not even *'s), and then will remove the package. If you are short on disk space, and do not use Libreoffice(An Open Source Office Suite), then you can remove all of Libreoffice from software center, or with sudo apt-get remove libreoffice-*.
- 15,318
- 20,906
The Terminal provides a text-based command-line interface and is very powerful and useful.
However, as Culumus007 has said, it may not be the best tool for this task. Graphical user interface tools like the Ubuntu Software Center or the Synaptic Package Manager make it easy to search through installed packages, figure out which ones you want to remove, and to remove them.
You can do the same thing from the command line, using commands like sudo apt-cache search ..., sudo apt-get remove ... (or sudo apt-get purge ...), and sudo apt-get autoremove (or sudo apt-get --purge autoremove).
What you should not do is to remove the files manually.
- Even if the right files are removed, the system (specifically, the package manager) will still believe they're there, which can cause problems.
- When a package is installed, its files are distributed throughout different subdirectories of
/usr. It would be rather cumbersome and time consuming to find and delete them all manually, even if you worked from the lists of files provided by the packages you want to remove. - It's possible to remove the files manually, using either the Terminal or the file browser Nautilus. But for the reasons explained above, this is not a very good idea.
- If the files are removed, launchers to them will malfunction instead of being also removed, unless the Unity Launcher entries are also removed manually, causing a difficult process.
I've posted this as community-wiki (easier for others to edit, and I get no rep from it) because there are already good answers, and this is more of a guide to them than a separate answer. But I didn't want to try to cram this information into comments.
- 119,640
CTRL+ALT+T to open terminal.
Type
gksu nautilus.Input your password and press ENTER key.
Double-click on USR directory/folder to open it.
Locate the game folder you intend to delete, right-click on it and select 'Move to Trash'.
- 1,554
