After chasing around an unfortunate bug wherein my Dell's Nvidia GeForce FX 5200 requires a driver other than either nouveau or nvidia-current, I came across this: https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-173/+bug/948053
Trouble is I'm not certain how to proceed from here - and I'm also really, really cautious about doing this, because the last two or three times I tried to install drivers for this card I ended up with bad resolution and/or a blank screen, and I did end up reinstalling Ubuntu at least once.
I'm fairly positive that there's no error with the card as it worked under Windows XP on the same machine not a month ago, so I believe the error was human. :/ What's the best way to install based on the information in the link above, and if it goes belly up, what's the right way to reverse it? I'm not terribly excited to reinstall again :) Thanks.
Stick
  • 359
At least for my part, I believe this is solved.
Recently, the driver I was reading much about - 173.14.35 - was released in a means that I could access and install using apt-get. The link in the original question leads to the announcement that nvidia-173 on precise-proposed has been updated to xxx.xx.35, and so it's a matter of following the directions listed on this page: https://wiki.ubuntu.com/Testing/EnableProposed
As this is a rather new fix, I will not guarantee it works for everyone with a legacy Nvidia card under Ubuntu 12.04. But for my money this was far favorable to downgrading Xorg or rolling back to an older OS.
Stick
  • 359
The following simple steps worked for me for version 12.04.02 on March 19, 2013.
  • Install 12.04.02 (DO NOT enable auto login).
  • When the install finishes rebooting, you will be at the login screen (DO NOT LOGIN).
  • CTRL-ALT-F1 to get to a command-line.
  • login at the command prompt
  • sudo apt-get install nvidia-173-updates (DO NOT INSTALL nvidia-173)
  • reboot
  • enjoy
r233967
Nvidia 173 drivers to work is by downgrading the xorg-xserver, so this is what we're going to do.........
Create /etc/apt/sources.list.d/oneiric.list and add the oneiric repo (You can copy/paste the text of the following entirely on a terminal
sudo -s
sudo cat >/etc/apt/sources.list.d/oneiric.list <<EOF
deb http://archive.ubuntu.com/ubuntu oneiric main
deb-src http://archive.ubuntu.com/ubuntu oneiric main
EOF
You will need also to perform a "pinning" so the xserver-xorg will be chosen and kept to be the older version and not the latest.
Create a new file in /etc/apt/preferences.d/
cat > /etc/apt/preferences.d/xorg-xerver-pin-1050 <<EOF
Package: xorg xserver-xorg*
Pin: release a=oneiric
Pin-Priority: 1050
Then run,
sudo apt-get update & sudo apt-get dist-upgrade
This will warn you it's going to downgrade a lot of "xorg" related packages, that's exactly what we need
Download Nvdia-173 driver from here
Once downloaded, you need to stop the GUI, so get to the terminal by pressing Ctrl+Alt+F1 login with your user and stop the xserver with
sudo service lightdm stop
Go to the place where you saved it (most probably in your home downloads folder)
cd ~/Downloads
and run the following
sudo chmod +x NVIDIA-Linux-x86-173.14.31-pkg1.run & sudo ./!$
Follow the onscreen instructions, mostly "yes" to all and once it finishes reboot the computer. Voila! You're now using the nvidia driver with full 3D support! If you want to configure other settings, you can use the nvidia-settings application that you have now installed. If you change something and want to save it, you'll have to run it as root, so you better fire it up by pressing Alt+F2 and on the command type gksu nvidia-settings
Kaktarua
  • 1,934
Just add the following to your /etc/apt/sources.list file:
deb http://cz.archive.ubuntu.com/ubuntu precise-updates main restricted
Then you can
I had nvidia-304 installed so I had to do:
sudo apt-get install -f
