Isn't there a way to force all apps to start up minimized or make them load in the background so they won't be opened on top of the window that I'm working on, besides making the window to be always on top?
I notice lot of similar questions like this one get blindly answered with solution that involves fiddling with window rules setting in CompizConfig > General > Focus & Raise Behavior but that actually does nothing to prevent this kind of focus stealing.
Tom Brossman
  • 13,297
Flint
  • 3,201
Check GDevilSpie from the Software Center, here is a tutorial http://www.webupd8.org/2011/02/how-to-start-applications-minimized.html
MeM
  • 36
If you are using workspaces (called viewports in Compiz), you can use devilspie2 to open applications maximalized in a different workspace. It uses lua as its scripting language so it is quite powerfull. It does not work that well with viewports as they are technically only a section of one big workspace, so some workarounds and external tools are needed. This is a script I use to place pidign conversation to viewport 3,3 (third from the top and left) of my fullHD screen (1920×1080):
-- a helper function to capture string from external command output
function os.capture(cmd, raw)
  local f = assert(io.popen(cmd, 'r'))
  local s = assert(f:read('*a'))
  f:close()
  if raw then return s end
  s = string.gsub(s, '^%s+', '')
  s = string.gsub(s, '%s+$', '')
  s = string.gsub(s, '[\n\r]+', ' ')
  return s
end
if (get_window_class()=="Pidgin" and get_window_role()=="conversation") then
    -- get the current viewport
    vp = os.capture("xprop -root |grep '_NET_DESKTOP_VIEWPORT(CARDINAL) = ' |cut -d ' ' -f 3-4 |tr -d ','")
    -- unfortunately, the below does not work due to a bug in xdotool
    -- vp = os.capture("xdotool get_desktop_viewport")
    -- set_window_geomtery is relative to current position, it seems, so go to the left and top most vieport
    os.execute("xdotool set_desktop_viewport 0 0")
    -- set the window maximized and to viewport 3,3
    set_window_geometry(3930,2250,650,950)
    maximize()
    -- now go to the original viewport
    os.execute("xdotool set_desktop_viewport " .. vp)
end
The script depends on x11-utils and xdotool. It results in a very short flicker when the app is open. It can be eliminated by using CCSM and setting Wall sliding duration time to zero milliseconds.
sup
  • 4,964
