I recently installed a fresh version of Ubuntu LTS 12.04. I had been using LTS 10.4 and saved my package.list and was planning on using
$> sudo dpkg --set-selections < package.list && apt-get dselect-upgrade
to install the same packages in the new version
However, the computer fails to run with the error
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
The simple answers to this would be am I root or a member of sudo?
  $> whoami
  surfer
   $> groups
surfer adm cdrom sudo dip plugdev lpadmin sambashare
So much for the easy answer.
Per the similar post Unable to lock the administration directory (/var/lib/dpkg/) is another process using it? The recommended solution is
$> sudo fuser -cuk /var/lib/dpkg/lock; sudo rm -f /var/lib/dpkg/lock
Upon executing that command, my screen goes blank, the keyboard becomes unresponsive, and my only option is to press the power button and reboot... (I would have thought this was a malicious suggestion, but many others seemed to have liked it.)
I've tried listing any programs that may be using /var/lib/dpkg/lock
$> sudo lsof
lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/surfer/.gvfs
      Output information may be incomplete.
Note, there are no programs listed.
Similarly, no luck with
$> ps -e | grep -e apt -e adept | grep -v grep
Nothing listed.
BTW, I can run apt-get from the command line.
$> sudo apt-get update
runs as expected and updates my package lists...
@izx: After attempting your suggestion, I could not run
It failed with the same error. I tried this
a) immediately following the rm command in the F1 terminal
b) executing the rm command and returning to X with Ctrl+Alt+F7
c) executing the rm command and rebooting
Of interest only option c) yielded a different (but similar error message) which was
dpkg: error: dpkg status database is locked by another process
Although I cannot kill the processes using /var/lib/dpkg/lock with fuser, I did get the following output for processes that are linked to it.
$> fuser -cv /var/lib/dpkg/lock
                     USER        PID ACCESS COMMAND
/var/lib/dpkg/lock:  root     kernel mount (root)/var
                     surfer     1641 ....m (surfer)gnome-settings-
                     surfer     1656 ....m (surfer)compiz
                     surfer     1679 ....m (surfer)nm-applet
                     surfer     1688 ....m (surfer)nautilus
                     surfer     1731 ....m (surfer)gtk-window-deco
                     surfer     1733 ....m (surfer)unity-panel-ser
                     surfer     1831 ....m (surfer)gnome-terminal
                     surfer     1899 f.... (surfer)unity-applicati
                     surfer     2029 F...m (surfer)update-notifier
So I tried killing each process from the F1 terminal, and removed the lock file. No problem. The result was
$> ls /var/lib/dpkg/lock
ls: cannot access /var/lib/dpkg/lock: No such file or directory
file and links seem to be gone, but upon executing the dpkg command, I get the same error...and the lock file is back.
I'm really rather puzzled, and would welcome any help.
5 Answers5
10
Your very First step should have been
sudo dpkg --set-selections < package.list && sudo apt-get dselect-upgrade
The following error
would have never occurred , Even second time you used the same code, and got same error.
Try the right command by adding sudo as per above , and post your findings.
NOTE : The use of && enables you to execute multiple commands on same line , in the usual sense && only executes the second command if the first command returns a value reporting success . Therefore ,sudo here needs to be specified in second command .
atenz
  • 12,858
sudo dpkg --configure -a
Then retry.
This problem can also arise if there are other installations running.
Eliah Kagan
  • 119,640
Try with
sudo apt-get update
If u still get lock error try this command It will give the process detail
Then kill the process using process ID then execute the update command
And also u can delete this file your problem will solve
rm /var/lib/dpkg/lock
Premkumar
  • 351
I had the same error, this worked for me:
This error indicates that you (or some program/script) changed the permissions of the file /var/lib/dpkg/status. Please change them back via: "sudo chmod 644 /var/lib/dpkg/status" in order to fix the issue.
I ended up opening terminal:
sudo nautilus
navigating to the folders/files, and changing permissions to
ME - FOLDER:FULL ACCESS / FILES: READ WRITE
ROOT - FOLDER: FULL ACCESS / FILES: READ ONLY
The problem came when my permissions got screwed when trying to fix a kernel issue I had with an Nvidia driver... but that's another story..
I hope this helps...
pst007x
  • 8,210
In rare times, you can get this problem without other dpkg process locks by user with sudo privilege.
I encountered this problem for unknown reasons that I got this folder lost.
I tried all the other solutions suggested here, but none worked. My simple way was to copy a /var/lib/dpkg folder from another server with the same version Ubuntu.
Hope it helps if someone else had the same thing happen to them.
Eliah Kagan
  • 119,640
samuel
  • 101
