40
Whenever trying to install any software and update manger,
I get an error stating
Package operation failed
The installation or removal of a software package failed
When I run sudo apt-get update I got this result:
conan51xd@conan51xd-Lenovo-B470:~$ sudo apt-get -f install
[sudo] password for conan51xd:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
conan51xd@conan51xd-Lenovo-B470:~$ apt-get update
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Braiam
  • 69,112
user66498
  • 547
This line says you are not authorized to install/update. You need to be root to do it....
You can add sudo before apt-get or you can do sudo -s to be root.
Example: sudo apt-get update
or
sudo -s will consider you as root until you close your terminal.
Then
apt-get update
Kaktarua
  • 1,934
  1. sudo -s (gives the root access)
  2. apt-get update (get the updates)
  3. apt-get upgrade (upgrades the system)
apt-get update && apt-get upgrade doesn't work on every system so run the commands separately.
Benedict
  • 101
I had the same error, this worked for me:
This error indicates that you (or some program/script) changed the permissions of the file /var/lib/dpkg/status. Please change them back via: "sudo chmod 644 /var/lib/dpkg/status" in order to fix the issue.
I ended up opening terminal:
sudo nautilus
navigating to the folders/files, and changing permissions to
ME - FOLDER:FULL ACCESS / FILES: READ WRITE
ROOT - FOLDER: FULL ACCESS / FILES: READ ONLY
The problem came when my permissions got screwed when trying to fix a kernel issue I had with an Nvidia driver... but that's another story..
I hope this helps...
pst007x
  • 8,210
-3
Run this command:
sudo mv /var/lib/apt/lists{,july12}
sudo apt-get update
Then sudo apt-get upgrade
drake01
  • 3,515
