14
I am using ubuntu 12.04. I had installed ffmpeg a while ago (so don't clearly remember whether it was from source or repo). Now, I am unable to uninstall it. I have tried the followin:
$ sudo apt-get remove ffmpeg
$ sudo apt-get purge ffmpeg
I tried to find ffmpeg directory by issuing the following command:
$ find / -name 'ffmpeg' -type d
This gave me /home//ffmpeg. When I changed to the directory, I found ffmpeg and ffmpeg1, however "sudo make uninstall" didn't work for both the places and threw an error "make: * No rule to make target `uninstall'. Stop.". That, I suppose, would mean that it was not the source from which ffmpeg was (if) compiled.
When I issue the following command:
$ffmpeg -version
I get:
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
  built on Jun 12 2012 16:37:58 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
ffmpeg 0.8.3-4:0.8.3-0ubuntu0.12.04.1
libavutil    51. 22. 1 / 51. 22. 1
libavcodec   53. 35. 0 / 53. 35. 0
libavformat  53. 21. 0 / 53. 21. 0
libavdevice  53.  2. 0 / 53.  2. 0
libavfilter   2. 15. 0 /  2. 15. 0
libswscale    2.  1. 0 /  2.  1. 0
libpostproc  52.  0. 0 / 52.  0. 0
Jorge Castro
  • 73,717
gentrobot
  • 243
For reasons discussed in this question, the "ffmpeg" in Ubuntu 12.04 is actually provided by the libav-tools package; that's why removing the ffmpeg package seemingly does nothing.
To really remove it:
sudo apt-get --purge remove libav-tools
sudo apt-get --purge autoremove
Note: The contents of the 2.2 kB ffmpeg package deb file as provided by libav simply pulls in libav as dependencies...
ish
  • 141,990
