18
I have a number of LVM partitions, each containing an Ubuntu installation. Occasionally, I want to do an apt-get dist-upgrade, to update an installation to the most recent packages. I do this with chroot - the process is usually something like:
$ sudo mount /dev/local/chroot-0 /mnt/chroot-0
$ sudo chroot /mnt/chroot-0 sh -c 'apt-get update && apt-get dist-upgrade'
$ sudo umount /mnt/chroot-0
[ not shown: I also mount and unmount /mnt/chroot-0/{dev,sys,proc} as bind-mounts to the real /dev, /sys and /proc, as the dist-upgrade seems to expect these to be present ]
However, after upgrading to precise, this process no longer works - the final umount will fail because there are still open files on the /mnt/chroot-0 filesystem. lsof confirms that there are processes with open files in the chroot. These processes have been started during the dist-upgrade, I'm assuming this is because certain services in the chroot need to be restarted (eg, through service postgresql restart) after the package is upgraded.
So, I figure I need to tell upstart to stop all the services that are running within this chroot. Is there a way to reliably do this?
I've tried:
cat <<EOF | sudo chroot /mnt/chroot-0 /bin/sh
# stop 'initctl' services
initctl list | awk '/start\/running/ {print \$1}' | xargs -n1 -r initctl stop
EOF
Where initctl list seems to do the right thing and only list processes that have been started in this particular root. I've tried adding this too, as suggested by Tuminoid:
# stop 'service' services
service --status-all 2>/dev/null |
    awk '/^ \[ \+ \]/ { print \$4}' |
    while read s; do service \$s stop; done
EOF
However, these doesn't seem to catch everything; processes that have daemonised and been reparented to PID 1 don't get stopped. I've also tried:
sudo chroot /mnt/chroot-0 telinit 0
But in this case, init doesn't distinguish between the separate roots and shuts down the entire machine.
So, is there any way to tell init to stop all processes in a particular chroot, so that I can safely unmount the filesystem? Does upstart have any facility to SIGTERM/SIGKILL all child processes (as would be done during regular shutdown) within a chroot?
Jeremy Kerr
  • 27,829
6 Answers6
18
I don't trust anything but the kernel to keep a sane state here, so I don't (ab)use init to get this job done, nor do I count on myself actually knowing what is or isn't mounted (some packages can mount extra filesystems, like binfmt_misc). So, for process slaughter, I use:
PREFIX=/mnt/chroot-0
FOUND=0
for ROOT in /proc/*/root; do
    LINK=$(readlink $ROOT)
    if [ "x$LINK" != "x" ]; then
        if [ "x${LINK:0:${#PREFIX}}" = "x$PREFIX" ]; then
            # this process is in the chroot...
            PID=$(basename $(dirname "$ROOT"))
            kill -9 "$PID"
            FOUND=1
        fi
    fi
done
if [ "x$FOUND" = "x1" ]; then
    # repeat the above, the script I'm cargo-culting this from just re-execs itself
fi
And for umounting chroots, I use:
COUNT=0
while grep -q "$PREFIX" /proc/mounts; do
    COUNT=$(($COUNT+1))
    if [ $COUNT -ge 20 ]; then
        echo "failed to umount $PREFIX"
        if [ -x /usr/bin/lsof ]; then
            /usr/bin/lsof "$PREFIX"
        fi
        exit 1
    fi
    grep "$PREFIX" /proc/mounts | \
        cut -d\  -f2 | LANG=C sort -r | xargs -r -n 1 umount || sleep 1
done
As an addendum, I'd point out that approaching this as an init problem is probably the wrong way to look at it, unless you actually have an init in the chroot and a separate process space (ie: in the case of LXC containers). With a single init (outside the chroot), and a shared process space, this is no longer "init's problem", but rather just up to you to find the processes that happen to have the offending path, hence the above proc walk.
It's not clear from your initial post if these are fully-bootable systems that you're just upgrading externally (which is how I read it), or if they're chroots that you use for things like package builds. If it's the latter, you might also want a policy-rc.d in place (like the one dropped in by mk-sbuild) that just forbids init jobs starting in the first place. Obviously, that's not a sane solution if these are meant to be bootable systems as well.
infinity
  • 406
Just a contracted version of the chosen answer
Regex may be used to address multiple chroots at once.
Kill all processes in single or multiple $CHROOTS.
bash
for p in /proc/*/root; do [[ `readlink $p` =~ ^$CHROOTS ]] && kill ${p//[^0-9]/}; done
perl (faster)
perl -e "kill 15, map {/\d+/;\$&} grep {readlink =~ m:^$CHROOTS:} @ARGV" /proc/*/root
Umount single $CHROOT recursively.
bash
i=20; while ! umount -R "$CHROOT" && ((--i)); do sleep 1; done
Umount multiple $CHROOTS recursively.
bash
i=20; while ((i--))&&sleep 1&&a=`sed -nr "s:^\S+ ($CHROOTS) .*:\1:p" /etc/mtab`&&[[ $a ]]; do xargs umount -qR<<<"$a";done
Alek_A
  • 690
You already identified the problem yourself: Some things run service ... during dist-upgrade and service isn't part of Upstart, but part of sysvinit. Add similar awk magic around service --status-all to stop sysvinit services as you used for Upstart services.
Tuminoid
  • 3,932
I know this question is pretty old, but I think it is as relevant today as it was in 2012, and hopefully someone finds this code useful. I wrote the code for something I was doing, but thought I'd share it.
My code is different, but the ideas are very similar to @infinity (in fact - the only reason I now know about /proc/*/root is because of his answer - thanks @infinity!). I also added some cool additional functionality
#Kills any PID passed to it
#At first it tries nicely with SIGTERM
#After a timeout, it uses SIGKILL
KILL_PID()
        PROC_TO_KILL=$1
        #Make sure we have an arg to work with
        if [[ "$PROC_TO_KILL" == "" ]]
        then
                echo "KILL_PID: \$1 cannot be empty"
                return 1
        fi
        #Try to kill it nicely
        kill -0 $PROC_TO_KILL &>/dev/null && kill -15 $PROC_TO_KILL
        #Check every second for 5 seconds to see if $PROC_TO_KILL is dead
        WAIT_TIME=5
        #Do a quick check to see if it's still running
        #It usually takes a second, so this often doesn't help
        for SEC in $(seq 1 $WAIT_TIME)
        do
                sleep 1
                if [[ "$SEC" != $WAIT_TIME ]]
                then
                        #If it's dead, exit
                        kill -0 $PROC_TO_KILL &>/dev/null || break
                else
                        #If time's up, kill it
                        kill -0 $PROC_TO_KILL &>/dev/null && kill -9 $PROC_TO_KILL
                fi
        done
Now you would do 2 things to make sure chroot can be unmounted:
Kill all processes that may be running in the chroot:
CHROOT=/mnt/chroot/
#Find processes who's root folder is actually the chroot
for ROOT in $(find /proc/*/root)
do
        #Check where the symlink is pointing to
        LINK=$(readlink -f $ROOT)
        #If it's pointing to the $CHROOT you set above, kill the process
        if echo $LINK | grep -q ${CHROOT%/}
        then
                KILL_PID $PID
        fi
done
Kill all processes that may be running outside of the chroot, but interfering with it (ex: if your chroot is /mnt/chroot and dd is writing to /mnt/chroot/testfile, /mnt/chroot will fail to unmount)
CHROOT=/mnt/chroot/
#Get a list of PIDs that are using $CHROOT for anything
PID_LIST=$(sudo lsof +D $CHROOT 2>/dev/null | tail -n+2 | tr -s ' ' | cut -d ' ' -f 2 | sort -nu)
#Kill all PIDs holding up unmounting $CHROOT
for PID in $PID_LIST
do
        KILL_PID $PID
done
Note: Run all code as root
Also, for a less complex version, replace KILL_PID with either kill -SIGTERM or kill -SIGKILL
Tal
  • 101
jchroot: a chroot with more isolation.
After your command has been executed, any process started by the execution of this command will be killed, any IPC will be freed, any mount point will be unmounted. All clean!
schroot is not yet able to do this, but this is planned
I have tested it successfully in OpenVZ VPS, which can not use docker or lxc.
Please read the author's blog for the details:
https://vincent.bernat.im/en/blog/2011-jchroot-isolation.html
Like
  • 181
-1
schroot: It has the feature of session management. When you stop the session its all processes are killed.
https://github.com/dnschneid/crouton/blob/master/host-bin/unmount-chroot: This scripts kill all the chroot process and unmounts all the mounted devices.
sdkie
  • 111
