I recently installed Pidgin and tried to install pidgin-facebookchat. Ubuntu software center now says that pidgin is corrupt so I press repair but nothing gets fixed.
I've tried sudo apt-get purge pidgin but I get this error:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
pidgin-data : Breaks: pidgin-facebookchat (< 1.69-2) but 1.69 is to be installed
pidgin-libnotify : Depends: pidgin (< 1:3.0) but it is not going to be installed
Depends: pidgin (>= 1:2.10) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
And sudo apt-get -f install results in this error
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
language-pack-kde-zh-hans-base firefox-locale-zh-hans language-pack-kde-en kde-l10n-engb
language-pack-zh-hans-base kde-l10n-zhcn language-pack-zh-hans language-pack-kde-zh-hans
language-pack-kde-en-base
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
pidgin-facebookchat
The following packages will be upgraded:
pidgin-facebookchat
1 upgraded, 0 newly installed, 0 to remove and 31 not upgraded.
1 not fully installed or removed.
Need to get 0 B/39.8 kB of archives.
After this operation, 139 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: warning: there's no installed package matching pidgin-facebookchat:amd64
How can I uninstall Pidgin from my computer?, It is also blocking other applications from being installed.
