13
I installed the c++ boost development libraries using Ubuntu software centre. The problem is that it was quite a long time ago and I cannot remember where they are installed nor what version they were. Is there anything I can do from the command line that will tell me what version(s) I have installed on my system?? I know I can do things like
gcc -v
to get version of an application but is there a similar thing available for libraries? I am using ubuntu 12.04
You can quickly find what version or where a library is, even if you do not quite know the title, with dpkg, and, in your case, using boost as the query term:
dpkg -l '*boost*'
and then query dpkg again with this option for a full list of file locations now you know the name of the file:
dpkg -L <'name of lib'>
The name of the library may, for example, be libboost1.46-dev.
ldconfig -v requires sudo.
All you really need is to query it, so this will do.
ldconfig -p | grep [name]
Carl
  • 181
Use ldconfig -v to print libraries and current version number and grep to filter your results ldconfig -v | grep [name].
It is better to find the packadge of the lib with dpkg -S libXYZ.so.N.
Than do apt-cache showpkg libXYZ and the version numbers is shown.
musbach
  • 1,505
