So, I'm trying to publish my app in my PPA, but I'm having problems related with building my app. Here you have the output:
/bin/sh: 1: glib-compile-schemas: not found
make[1]: *** [override_dh_install] Error 127
make[1]: Leaving directory `/build/buildd/virtuam-0.1ubuntu1'
make: *** [binary] Error 2
dpkg-buildpackage: error: /usr/bin/fakeroot debian/rules binary gave error exit status 2
Build finished at 20120709-2102
FAILED [dpkg-buildpackage died]
Even following the solutions posted in https://askubuntu.com/questions/156339/launchpad-failed-to-build-after-quickly-submitubuntu, I have no luck. What should I do?
The build error is this: https://launchpadlibrarian.net/109704402/buildlog_ubuntu-precise-i386.virtuam_0.1ubuntu1_FAILEDTOBUILD.txt.gz
Xerz
  • 4,591
Your build dependencies are incomplete. From your build log I can see that it tries to install (upgrade) the libglib2.0-0 package. However, glib-compile-schemas is provided by the libglib2.0-bin package which is not a dependency of libglib2.0-0.
To solve this, add libglib2.0-dev as build dependency which will install both libglib2.0-bin and libglib2.0-0.
Lekensteyn
  • 178,446
It looks like you aren't specifying all of your build dependencies in the debian/control file.
dobey
  • 41,650
The missing dependency on libglib2.0-bin for glib-compile-schemas is actually a quickly bug. The fix is in precise-proposed. See https://askubuntu.com/questions/156339/launchpad-failed-to-build-after-quickly-submitubuntu.
