What I'd like to do is be able to start external programs from links in a local website.
I've defined a custom protocol handler in firefox by setting the following variables in about:config
network.protocol-handler.external.myprotocol;true
network.protocol-handler.warn-external.myprotocol;true
This successfully causes firefox to open a 'launch application' dialog box when I click on a link in the form myprotocol:///path_to_program_I_want_to_run, and then I browse to the shell script I want to use and tell firefox to run it. Unfortunately the script doesn't seem to be run at all.
I've set the file permissions to 777 so firefox shouldn't have any trouble running it
The shell script originally only contained the line
$1
The idea being that the path of the link would be passed in as the first argument and would immediately be run as a program. This worked fine when I ran the script myself using commands like
#./run_program.sh gedit
or
#./run_program.sh /home/ciaran/test_program
The script now for testing purposes contains only the line
echo "testing" > /testing/file.txt
where 'testing' is a directory with 777 permissions. Also note that /testing/ actually is located at the root of my filesystem (though i can't remember why i put it there!), so I haven't just gotten mixed up between relative and absolute paths
Again, this runs perfectly fine when I run it from the terminal, and file.txt is created in the right location. With firefox though, I am given the option to choose an application to run, I choose that shell script, and it doesn't seem to do anything.
file.txt is not created at all, though there are no permission issues that I can see. So firefox just doesn't seem to be running the script.
I have also tried changing my about:config to contain
network.protocol-handler.expose.camara;true
and
network.protocol-handler.app.camara;path/to/shell/script
with no success
