I unexpectedly deleted my user account (the only administrator for the machine). I have another account which is a standard account and now I can't access my hard disk or anything with that standard account - it is asking for the root password. Is there any way I can recover access to the administrator account?
You can use recovery mode to add the standard user to the admin group (which is now called sudo in 12.04). Below is a set of simple instructions copied from my personal website.
Using Recovery Mode To Add Users To The Admin / Sudo Group
First shutdown your computer.
Then restart whilst holding shift on the keyboard to load grub menu.
Select recovery mode from the grub menu.
Select drop to root shell from the recovery menu.
Use the following command to remount the drive mount -o rw,remount /
Now type adduser username sudo replacing username with your user name ie. 'adduser phil sudo'
You should now see a message saying 'adding user' followed by 'done'.
Type shutdown -r now to restart the computer.
EDIT: If it is telling you that user xxx does not exist, first you can use the following command to list users and make sure that you have the correct username
ls /home
The other option is add a new user, from recovery mode using the following commands :
useradd username -m -s /bin/bash
passwd username
Again replacing username with your desired username.
- 3,899
You can use the recovery console and boot as root this is a extra option on your grub menu and create a new user then add them to the admin group. I'm not sure if this will fix your issue, but give it a try and let me know.
useradd newuser
adduser newuser admin
- 3,899
- 4,860
I had the same problem Select recovery mode (if you are using laptop it differents but it's in the same place you get in bios) Then select root Write the command(# adduser ) Then the command(# password root) And write the new password And restart by the command( #reboot)
- 1
