/usr/bin/perl install-module.pl --all
ERROR: Using install-module.pl requires that you install "make".
I need to install make on my ubuntu on AWS EC2. How can I do that ? I could finally install build-essential also successfully.
# make
make: *** No targets specified and no makefile found.  Stop.
Jorge Castro
  • 73,717
Deepak Singhal
  • 1,797
In this situation, the make command is already installed.
# make
That means make actually ran, but failed because there is no file called Makefile in the current directory.
The problem here is that perl is not able to find make even though it is installed. As ændrük commented, this has been asked on Server Fault. Since ændrük's comment, solutions have been posted there.
According to quanta, this can be fixed by running perl -MCPAN -e shell and then, at the cpan> menu, install Math::Random::Secure.
According to ocach, this can be fixed by running cpan followed by these two commands on the cpan[n] prompt:
o conf make '/usr/bin/make' #or path to your make
o conf commit
I tried ochach's way on my machine, and it seemed to work:
cpan[1]> o conf make '/usr/bin/make'
    make               [/usr/bin/make]
Please use 'o conf commit' to make the config permanent!
cpan[2]> o conf commit
commit: wrote '/home/ek/.cpan/CPAN/MyConfig.pm'
I recommend trying those techniques; it seems likely one of them will solve your problem.
Eliah Kagan
  • 119,640
