122
Is there anyway to get an error log for a failed VPN connection attempt? All I get is this notification and I have no idea where to go from there.
Zanna
  • 72,312
7 Answers7
132
Log is written to /var/log/syslog.
Open gnome-terminal and do sudo tail -f /var/log/syslog
This will follow the file (prints to terminal new log messages).
Now try to connect to the vpn, the messages then will start showing in the terminal.
When you are done following the log just click Ctrl+c to quit tail.
One can add markers to the log by opening another terminal and doing something like that:
logger "............... Starting VPN... "
kroiz
  • 1,579
84
The new (systemd-)variant to get the logs is
journalctl -u NetworkManager.service
Matthias Weiler
  • 964
In Fedora and other systemd distro's that do not have /var/log/syslog, the VPN logs can be accessed with "sudo journalctl -f"
-f is for follow.
Ray Foss
  • 393
What kind of VPN are you trying to establish?
Is it PPTP (Microsoft proprietary) or Cisco-compatible ?
The easiest way would be for you to run pptp (for PPTP) or vpnc (for Cisco) from a console and see the possible errors interactively.
I think that vpnc is quite straight forward, you just need to type in the necessary info (gateway ip, group name/pass, user name/pass).
I haven't actually used a PPTP VPN, but some info about setting it up can be found here at cyberciti
Zanna
  • 72,312
Pavlos G.
  • 8,954
Try enabling "Advanced" -> "Use Point to Point Encryption (MPPE)", this worked for me.
Lyubomir
  • 191
Open the Advanced options, and tick Use a TCP connection. That fixed it for me. Ubuntu 14.04 LTS, OpenVPN.
Zanna
  • 72,312
I just confirm the problem on ubuntu 14.04 LTS.
Add that if you launch the vpn manually with the following command it works at least for me:
sudo vpnc --domain "" --local-port 0 --enable-1des mypcffile
