I'm running 12.04LTS.
So I asked this same question on the ubuntuforums and was recommended to get a new drive. I've done that and still have the same problem. Here's the original (http://ubuntuforums.org/showthread.php?p=11981491):
Hi there. So, let me preface this by saying that the drive in question was working. I used it to install 11.10 before upgrading to 12.04. I also used it to install the Win7 dual boot partition.
I'm running 12.04 64bit.
The drive is a Samsung SH-222. I can no longer access the drive in Windows or Ubuntu and I can't even use bootable CD/DVD even though it appears in my BIOS launch options. The drive is receiving power and opens, but if a disc is loaded I get no response (in either OS).
Here's fstab - Quote:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass> proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sda1 during installation UUID=8f568673-81d3-40f0-aade-3f77fb65b151 / ext4 errors=remount-ro 0 1
# /windows was on /dev/sda4 during installation UUID=79753E43529B03B9 /windows ntfs defaults,umask=007,gid=46 0 0
# swap was on /dev/sda5 during installation UUID=4d558b02-e348-4010-bbce-8a5ff8130c8a none swap sw 0 0
Here's lspci...
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation H61 Express Chipset Family LPC Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 4 port SATA IDE Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
00:1f.5 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 2 port SATA IDE Controller (rev 05)
02:00.0 Ethernet controller: Atheros Communications Inc. AR8151 v2.0 Gigabit Ethernet (rev c0)
My main HDD is also SATA and is being read fine. I'm at a loss of why this is happening, not just in Ubuntu, but system wide.
Help would be greatly appreciated. This may have happened a week ago or a month ago, I'm really not sure. I so rarely use the DVD drive that I haven't had any reason to try, so I can't really pinpoint where/when it stopped working, sorry. If you need any additional information, I'll be more than happy to give it.
Thanks in advance.
So now, I have installed a brand new drive (same make/model) and am having the same outcome.
Here's the new lspci:
Any help or ideas would be greatly appreciated.
ish
  • 141,990
You have already tried a different DVD drive. In addition, first try a different SATA cable. If the drive continues to fail, try a different SATA port on your motherboard. Finally, try using a different power connector from your power supply (one that's on a different cable, if possible).
Michael Hampton
  • 1,860
  • 16
  • 27
