This really doesn't make sense. I've been using many other distros and never had such difficulty managing autostart services.
I found three ways of disabling autostart services, and none of them works for me:
update-rc.d -f service_name remove
chkconfig --level 12345 service_name off
sysv-rc-conf
I tried all the three ways to disable mysql daemon, mongo daemon, redis server, cups daemon, yet all of the utilities confirmed that the daemons are disabled, yet they still automatically start on boot.
Please suggest the most correct way to disable services from auto-start at boot. Thank you!
btw, it's running 12.04
Eliah Kagan
  • 119,640
Howard
  • 165
Ubuntu has been moving away from sysv-init to Upstart. Some scripts won't work with: (as they have been moved to the Upstart format)
sysv-rc-conf
This has been answered in other posts, best answer I've seen so far is: (if you want more documentation on it)
https://askubuntu.com/a/19324/23779
So in a brief comment:
The current situation is: Ubuntu now uses Upstart. Some services still use the old sysv-init, are located in /etc/init.d/ while other services, Upstart optimized are in /etc/init/. How to disable, stop, start, etc is explained in the above link.
Exodus
  • 91
Bum is good startup manager suggested by many Ubuntu Users . open your terminal and type as
sudo apt-get install bum
and to Launch the Bum , type this in your terminal .
gksu bum
Hope that helps .
Raja G
  • 105,327
  • 107
  • 262
  • 331
