I have several computers running Ubuntu. I also have a slow Internet connection.
If I install programs using apt-get, does that put installation files somewhere which I can access, so that I can use those to also install the same programs on my other Ubuntu machine instead of having to download the same thing multiple times from the net?
What's the way to do this?
Tim
  • 33,500
z-buffer
  • 333
5 Answers5
Yes it is possible.
Those file are stored in /var/apt/cache/archives.
  1. You can copy those files manually or use software like AptonCD.
    But this will require you to update the source file using apt-get which is also a pain in slow internet connections.
What I would recommend is to,
  1. Customize a live CD to include all necessary software and use that media to install it in other system.
    You use UCK for this purpose.
Another possible way is
  1. Install ubuntu in one computer. Update with necessary software.
    Use remastersys to create an image of your system and use it for installation in others.
Web-E
  • 21,716
You might want to take a look at apt-cacher or AptProxy which are designed exactly for your purpose.
Izzy
  • 3,620
Ubuntu have two releases every year 4 (April) and 10 (October) that's why programs largely depends on the version based dependencies of kernel or other libraries.
In case you got the right package for installation, you can use the following command to install from a binary .deb (debian package file).
sudo dpkg -i what_so_ever_is_the_package_name.deb
and for removing --
sudo dpkg -r what_so_ever_is_the_package_name
for repair or reconfigure --
sudo dpkg-reconfigure what_so_ever_is_the_package_name
Bharat
  • 101
Assuming that all Ubuntu installations are of Same Version and Architecture and also having same Package/ Application Installed state .
So the .deb you have downloaded on one of your machine are stored in
/var/cache/apt/archives/
  1. You can install by selecting the Main Package .deb file opened through Ubuntu Software Center or through gdebi core.
  2. Another way , if you use sudo apt-get install <package name> to install in main Ubuntu Machine, then after installing , go to the above path of files and copy them exactly into other PC's and run
sudo dpkg -i *.deb
at the same location , you may need Root permissions for that. Then you can issue the same commands to install them there.[ I think it does works].
You can also follow different methods through the Link provided by Mitch .
atenz
  • 12,858
I had the issue, that I had a machine completly without internet connection.
I solved it with this little Trick(s):
1st trick(good for you):
copy the whole apt-cache onto a empty usb-stick
$ sudo cp /var/cache/apt /media/your_username/name_of_usb_stick
then carry the usb stick to the other machine and mount the apt-cache on the usb stick to the apt-cache of your machine
$ sudo mount name_of_usb_stick /var/cache/apt
(you also can mount the apt-cache using nfs)
2nd trick:
(good if your machines are not similar)
First you install the same system on a usb stick(see here), after that you go to a machine with internet connection an boot from your usb system
Here you fetch the packages using
$ sudo apt-get install --download-only program-you-want-to-install
then shutdown your pc and carry the usb stick to the machine without internet connection, now link the apt-cache on the stick to your apt-cache
$ sudo ln -d /media/your_username/name_of_stick/var/cache/apt  /var/cache/apt
Then run
$ sudo apt-get install program_name
I hope this will help a few people
