I am following these instructions to create a Bootable USB Drive for me Mac and this is the output I get on step 8.
new-host:~ Jason$ sudo dd if=/Users/Jason/Desktop/ubuntu-12.04-desktop-amd64.dmg of=/dev/rdisk1s2 bs=1m
dd: /dev/rdisk1s2: Invalid argument
691+1 records in
691+0 records out
724566016 bytes transferred in 164.544659 secs (4403461 bytes/sec)
What should I do?
Eliah Kagan
  • 119,640
Jason
You should use unetbootin it is SO MUCH EASIER just reformat your disk and then throw the iso onto the flashdrive using unetbootin. http://unetbootin.sourceforge.net/
Dang! I might take a look at that. I made a 12.04 Live-USB for my Macbook 1.2, late 2007. It helped to have a working Live-CD so I could check Linux names for the USB stick, and so on. I used the instructions at ubuntu.com for making a Live-CD, but had to burn the disk 4-5 times before I got one that worked reliably.
I could NOT make a Live-USB following the directions at ubuntu.com. They may work for newer Macbooks, but not mine. I found a link to these instructions. Then I messed around with the grub.cfg file for days before I got:
# grub.cfg for MB1,2 USB Install F11
# Timeout for menu
timeout=20
default=0
menuentry "UBUNTU USB" {
       echo
       echo "FAKEBIOS"
       fakebios
       echo
       echo "SET ROOT"
       #set prefix=(hd1,2)/boot/grub
       #set root=(hd0,1)
       set root=(hd1,2)
       #set root=(hd1,2)/boot/grub
       #echo
       #echo "INSMOD"
       #insmod (hd1,2)/boot/grub/linux.mod
       echo
       echo "LINUX"
       linux /vmlinuz root=/dev/sdb2 video=efifb agp=off
       echo
       echo "INITRD"
       initrd /initrd.img
       echo
       echo "IMPLIED BOOT"
I found the echos very helpful. It gets all the way up to the implied boot and almost finishs, but failed mounting things on root, like /dev on /root/dev. I played around with the 'root=' arg on the linux command until hit on the one that there. I left a bunch of other stuff in comments. They didn't work for me, but they might for you.
I didn't find much out there. I even found a claim the Macbooks can't boot from a USB stick. I hope this helps.
Eliah Kagan
  • 119,640
