29
When I try converting mkv to mp4 using ffmpeg, the following error occurs:
version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers   built on Jun 12 2012 16:52:09 with gcc 4.6.3
 *** THIS PROGRAM IS DEPRECATED ***   This program is only provided for compatibility and will be removed in a future release. Please use
 avconv instead.   [matroska,webm @ 0x1e939c0] max_analyze_duration
 reached   [matroska,webm @ 0x1e939c0] Estimating duration from
 bitrate, this may be inaccurate   Input #0, matroska,webm, from
 'input.mkv':     Duration: 00:01:00.76, start: 0.000000, bitrate: 384
 kb/s
     Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x544, PAR 1:1 DAR 40:17, 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
     Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s (default)
     Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000   Output #0, ipod, to 'output.m4v':     Metadata:
     encoder         : Lavf53.21.0
     Stream #0.0(eng): Video: libx264, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], q=2-31, 25 tbn, 25 tbc (default)
     Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, 384 kb/s (default)   Stream mapping:     Stream #0.0 -> #0.0     Stream #0.1 -> #0.1
 Press ctrl-c to stop encoding   [ipod @ 0x1e9b740] Application
 provided invalid, non monotonically increasing dts to muxer in stream
 0: -2 >= -2 av_interleaved_write_frame(): Invalid argument
I used this command to convert the file:
ffmpeg -i input.mkv -vcodec copy -acodec copy -absf aac_adtstoasc output.m4v
The input file has the following characteristics:
mediainfo input.mkv
>General
>Unique ID                                : 200459305952356554213392832683163418790 (0x96CF0ED8DB5914CBB9E18163689280A6)
>Complete name                            : input.mkv
>Format                                   : Matroska
>Format version                           : Version 2
>File size                                : 1.46 GiB
>Duration                                 : 1h 5mn
>Overall bit rate                         : 3 168 Kbps
>Encoded date                             : UTC 2010-09-26 21:44:02
>Writing application                      : mkvmerge v2.9.5 ('Tu es le seul') built on >Jun 17 2009 16:28:30
>Writing library                          : libebml v0.7.8 + libmatroska v0.8.1
>Video
>Format                                   : AVC
>Format/Info                              : Advanced Video Codec
>Format profile                           : High@L3.1
>Format settings, CABAC                   : Yes
>Format settings, ReFrames                : 4 frames
>Codec ID                                 : V_MPEG4/ISO/AVC
>Duration                                 : 1h 5mn
>Bit rate                                 : 2 910 Kbps
>Width                                    : 1 280 pixels
>Height                                   : 720 pixels
>Display aspect ratio                     : 16:9
>Frame rate                               : 25.000 fps
>Color space                              : YUV
>Chroma subsampling                       : 4:2:0
>Bit depth                                : 8 bits
>Scan type                                : Progressive
>Bits/(Pixel*Frame)                       : 0.126
>Stream size                              : 1.31 GiB (90%)
>Writing library                          : x264 core 105 r1724 b02df7b
>Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=2910 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
>Default                                  : Yes
>Forced                                   : No
>Audio
>Format                                   : AC-3
>Format/Info                              : Audio Coding 3
>Mode extension                           : CM (complete main)
>Codec ID                                 : A_AC3
>Duration                                 : 1h 5mn
>Bit rate mode                            : Constant
>Bit rate                                 : 256 Kbps
>Channel(s)                               : 2 channels
>Channel positions                        : Front: L R
>Sampling rate                            : 48.0 KHz
>Bit depth                                : 16 bits
>Compression mode                         : Lossy
Stream size                              : 121 MiB (8%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Being new to ffmpeg, I'm not sure what the error means or how to correct it.
Thanks!
nanofarad
  • 20,906
JohnS
  • 291
6 Answers6
41
As I've already written here, I suggest you change a few details in your command line:
  • If you're using an Ubuntu release older than 15.04, replace ffmpeg for avconv, as it was the fork used by Ubuntu for a few years (see the comments)
  • Do you really need -absf aac_adtstoasc? It had some issues that may not have been corrected in current Ubuntu's ffmpeg. I suggest you to try without it first.
  • -vcodec copy -acodec copy can be simplified to -codec copy or -c copy. It would also prevent tampering other streams besides video and audio, like subtitles.
So the winner is...
ffmpeg -i input.mkv -c copy output.m4v
If that does not work, please post all terminal output.
MestreLion
  • 20,726
To automatically convert all files in a folder from MKV to MP4 you can create an alias:
alias mkv2mp4="for f in ./**/*.mkv; do ffmpeg -n -i \"\$f\" -c copy \"\${f%.mkv}.mp4\" && rm \"\$f\"; done"
This command performs the following steps:
  • Recursively loops through the current directory looking for .mkv files
  • Converts each file & all its sources to .mp4, not overwriting (-n) existing files
  • Removes the source file when the conversion was successful
I know its a very old thread, but I've found a solution to successfully run ffmpeg. Don't use -vcodec copy -acodec copy, use just ffmpeg -i input.mkv output.m4v instead. It will start running.
But in my case, I convert a .mkv to .mp4, the result output is just trash. It losses frame accuracy.
Using -codec copy didn't work for me (Ubuntu 22.04). Instead, this command did the trick:
  • Video-only mkv file:
    ffmpeg -i input.mkv -codec mpeg4 output.mp4
  • Video+audio mkv file:
    ffmpeg -i input.mkv -vcodec mpeg4 -acodec aac output.mp4
Notice that for an mkv file with audio track I had to explicitly specify that mpeg4 is the video codec (vcodec) and that aac is the audio codec (acodec).
Yuri Sucupira
  • 1,024
  • 15
  • 28
Try This one:: Libav in Linux
Installation: run command
sudo apt-get install libav-tools
Video conversion command::Go to folder contains the video and run in terminal
avconv -i oldvideo.mkv -ar 22050 convertedvideo.mp4
Stephen Rauch
  • 1,156
  • 15
Got this on Xubuntu 14.04 when trying to burn a DVD of MP4s using DVDStyler; Bombono produces the same error. ffmpeg #1154 suggests this might have been fixed in ffmpeg, though perhaps not in avconv? libav #478 is still marked open.
Also see: https://unix.stackexchange.com/questions/127522/avconv-error-av-interleaved-write-frame
I filed Launchpad #1339980; in summary, use a current release of ffmpeg, and not avconv.
