Sorry for the stupid question but I am new with Linux (I am using Gnome classic with Ubuntu 12.04) and I cannot set compiz in order to obtain the rotating cube.
I have already installed compizconfig-setting-manager and also the extra (and fusion) plugins but:
  • even if I disable the desktop wall and enable cube and rotating cube, nothing happens;
  • even if I change into general settings the number of vertical and horizontal virtual size nothing happens.
What I need is (possibly) a step by step answer.
Thank you
Ok...I solved my problem by using the command.
compiz --replace
which I have found looking around.
Can someone explain me what I have precisely performed with this command?
Thanks in advance
ish
  • 141,990
Keynesian
  • 63
With compiz --replace, you have replaced any existing window manager with Compiz; if you were already using Compiz, you have "reset" (or re-initialized) it -- which probably explains why this command solved your problem by finally applying your custom settings.
ish
  • 141,990
