I'm running 12.04 LTS on a PowerMac G5 and I have one problem. My wireless PCI card has my "Firmware Missing". I already know about Broadcom's poor wireless support with Ubuntu, and it's b43 however whenever I try to install the b43 firmware installer I get this:
snackadoodlepop@snackadoodlepop-desktop:~$ sudo apt-get install firmware-b43-installer
Reading package lists... Done
Building dependency tree
E: Unable to locate package firmware-b43-installer
NDIS Wrapper won't work on PowerPC to my knowledge. I'm stuck without WiFi and I need help!
SOLVED: Thanks to reddit's /r/linuxquestions, I was able to use the b43 firmware installer correctly.
esnowrackley
  • 563
  • 33
spent 2 days and nights trying to set up Ubuntu on my Ibook G4. wireless would not work. I did what said. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
sudo apt-get update && apt-cache search b43
then
you will need to type "y" to confirm disk space is used then it worked
Mitch
  • 109,787
zulf
  • 41
You need to:
To find the firmware package. Then again:
You have wireless (but might need to restart first).
esnowrackley
  • 563
  • 33
