I decided to wipe Windows 7 and made a full installation.
Everything works great but for a Encore N300 wireless usb dongle that I use on my desktop. Ubuntu seems to recognize it and I can browse the available networks, but I can connect to any of them. I was told that I should download its drivers, and so I did it, but I don't know how to install them.
Please, I'd like to know if my connectivity problem is really a driver issue or some other thing.
ish
  • 141,990
rafa
Can you open a terminal (search for terminal in dash) and type these two commands:
sudo modprobe -r rtl8192cu
sudo modprobe rtl8192cu swenc=1
Afterwards try to connect to a network. If it works you need to make it permanent, please check this question.
It will load the driver with a new value for the swenc parameter. I have no idea of what it does, but it seems to help sometimes.
¿Puedes abrir un terminal (búscalo en el dash), y escribe estos dos comandos (pulsa enter al final de cada linea)?
Después, intenta conectarte otra vez, Si funciona sigue el enlace de arriba para hacer el cambio permanente.
Javier Rivera
  • 35,434
