I am trying to get my installation of 10.04 to automatically log me in at start up. I tried to apply this method http://www.linuxjournal.com/article/3121 but after creating the script there, I was unable to edit the /etc/inittab file as there is not one present. Apparently this is because Ubuntu does not use this method and instead uses 'upstart'. Is there a similar way to auto login with Ubuntu??
Asked
Active
Viewed 2,506 times
mathematician1975
- 2,321
According to the fine manual, you need to edit /etc/gdm/custom.conf in 10.04. If you can live with a GUI solution, then:
- Load the Gnome Administration utility by clicking on System -> Administration -> Login Screen Settings
- Unlock the window by hitting the unlock button (you will be asked the administrator password)
- Enable the checkbox for Log in as UserName automatically (Select your User Name from the drop-down list of users)
dotancohen
- 2,864
