15
I use a USB drive to play music in my car. Unfortunately, the car does not sort the music alphabetically and relies on how the music is sorted on the FAT32 drive.
This Windows software here solves the problem. Anything comparable available for me on Ubuntu?
PS: at first I thought it was a file creation date problem askubuntu question. But although I figured out the answer to that question, it didn't solve the problem like I thought it would.
Chad--24216
  • 1,231
You might want to use fatsort which is available in Ubuntu and was designed to solve your exact problem. Cheers,
rmn
  • 181
fatsort solves the problem. First install fatsort then, list partitions in order to get the usb key device path
cat /proc/partitions
Let's take /dev/sde1 as an example.
Finally
sudo fatsort -f /dev/sde1
problem solved, without wine nor windows ;-)
FredFF
  • 91
Your best bet is to use DriveSort under Wine, as its author recommends
To quote DriveSort's author, the program is "tightly bound to Microsoft APIs", so I doubt you will find a native Linux equivalent where a non-native filesystem (FAT) is concerned.
You can run it under Wine as the author has tried and recommended, with some caveats:
  • You must run it with gksudo
  • You will need mfc42u.dll, which you can install in the same directory from the internet (google), or install it using the winetricks package.
  • Once sorting is completed, DriveSort attempts to unmount/remount the drive; remounting doesn't succeed in Wine, so you can either safely pull out the USB for use, or manually remount it.
ish
  • 141,990
It is a lazy solution, but you could just move the files out and than in again ...
create a temporary dir
mkdir /tmp/mydrive
move all files out
mv /media/thumbdrive/* /tmp/mydrive
and then all in again
mv /tmp/mydrive/* /media/thumbdrive
this might get the files in the thumbdrive in alfabetical order. I am not sure though ... Try it out
You might also want to look at: Sort files on the filesystem (same question) and at: http://www.murraymoffatt.com/software-problem-0010.html (some program recomendations)
josinalvo
  • 7,017
