I want to have text booting mode option on grub menu screen. How do I create this menu entry?
In my research, there are two ways to do this:
Method 1
Hack 10_linux script in /etc/grub.d/ and insert generation codes for text booting menuentry
Advantages:
- Generates text booting menuentry for all installed kernel versions
- Takes care of new or redundant menuentries when you install/purge kernels
Downsides:
- Requires deep understanding of shell scripting
- The script source file may vary from one grub version to another
- Edits need to be redone if grub package updates overwrite the modified script
Method 2
Use designated script for adding custom grub menuentry in /etc/grub.d
Advantages:
- Easiest and least complicated
- No chance of being overwritten so you do it only once
Downsides:
- Only if you want each of your installed kernel versions to have text
booting menuentry:
- Lots of work and harder to maintain
- Leaving behind redundant menuentries when you purge old kernel versions
In this short step, I'm going with method #2 since it's the easiest to explain here and we'll be creating text booting menuentry only for the latest kernel image that you use.
The first thing that you need is the already generated menuentry for your latest kernel. We are going to copy and use it as basis for our custom menuentry, with a little alteration. For that, you need to look in your
/boot/grub/grub.cfgfile. Locate the first menuentry stanza that points to the latest kernel on your Ubuntu. If you're dual booting with other linux distros, pay extra attention so you wouldn't mix it up with their menuentries.Once you found it, copy the entire menuentry stanza and paste it into
/etc/grub.d/40_customfile. It may look like one below. Let's use this as example:menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-a4e6d610-122e-42e2-8497-39eae02816e8' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio insmod part_gpt insmod ext2 set root='hd0,gpt2' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 a4e6d610-122e-42e2-8497-39eae02816e8 else search --no-floppy --fs-uuid --set=root a4e6d610-122e-42e2-8497-39eae02816e8 fi linux /boot/vmlinuz-3.8.0-31-generic root=UUID=a4e6d610-122e-42e2-8497-39eae02816e8 ro quiet splash $vt_handoff initrd /boot/initrd.img-3.8.0-31-generic }Now here's few things that you need to edit in this stanza before you can save the file:
- The menuentry title. Change 'Ubuntu' in
menuentryline to 'Ubuntu (text mode)' - Path to vmlinuz file in
linuxline. Substitute/boot/vmlinuz-3.8.0-31-genericwith/vmlinuzgrub boot parameter at the end oflinuxline. Substitutequiet splashwithtext - Path to initrd image in
initrdline. Substitute/boot/initrd.img-3.8.0-31-genericwith/initrd.img
Reason why we do the substitutions in both
vmlinuzandinitrdlines is to take advantages of the symlinks placed in / which points to their latest version in/bootdir so that our custom menuentry can always point to the most recent kernel and won't need to be changed if a new kernel is introduced.That's it. Execute
sudo update-grubto generate the custom menu and you're done.
- 2,182
- 3,201
