I may have a workaround that is relevant to you. I have a Kodak ESP 9250, and I was able to get it running as a printer under 11.04 (since upgraded to 12.04). I had the same error as you did when I tried to scan directly to the "USB Connected Computer" option.
However, I decided to try scanning to a USB drive plugged into the front of the printer - that worked, and since I had the printer hooked up to my laptop, and the cable was still connected, the USB drive was simultaneously mounted on my laptop!
So if you do a scan to "USB Flash drive", the drive is mounted under /media, and your files are in /media/(flashdrive ID)/DCIM/(printer ID)/.
This is not much better than just scanning to the flash drive directly and moving it, but hopefully this helps.
