I know to enter the file explorer in vim( by typing :e .). I am not sure how to exit the file explorer in vim. I typed :q and it gave me a segmentation fault. What should be the correct way to exit the file explorer in vim?
lakshmen
  • 133
:q should work just as fine with the "file explorer" as with any other open buffers. A segmentation fault suggests there's a serious bug in the version of vim you are using (or it could be a kernel bug or faulty RAM).
I tried this myself, but did not get a segmentation fault.
geirha
  • 47,279
I open the file explorer in the same buffer as the file by default using vim-vinegar.
I've managed to map Esc to delete the file explorer buffer and return me to the file I was editing, by putting this in .vimrc:
autocmd FileType netrw nmap <silent> <buffer> <Esc> :BD<cr>
:BD is a command supplied by the BufKill.vim plugin. You can just use :bd if you want to close the buffer normally.
darvelo
  • 121
