I have a dual boot system with
  1. C: drive with windows 227 GB
  2. E: drive in windows 185 GB
  3. Ext4 Ubuntu - 38 GB
  4. Linux swap - 4 GB
I want to decrease the space from E: drive from 185 GB to say about 160 GB and assign the 25 GB achieved from the resizing to the ext4 partition so that my Ubuntu home has more space.
I was told that do a resize in gparted could cause some boot problems, plase tell me a safe way to achieve this resizing.
Eric Carvalho
  • 55,453
Familiarize yourself with HowtoPartition
  1. Boot your Ubuntu CD/USB
  2. Select «Try Ubuntu» to get to the live session
  3. Run gparted
    1. Right click the swap partition and select unmount (if it is mounted).
    2. Shrink 2
    3. Move 3 to the left
    4. Grow 3 to fill the void to the right.
    5. «Apply»
There is always a risk of data loss when resizing and moving partitions. I've never had issues myself, but if the process get aborted in the middle of a resize, due to a power failure for instance, you'll be left with a broken system.
So make sure you have backups (on another drive/media) of files you cannot afford to lose.
As for boot problems. Unless you've done some extensive changes to /etc/fstab or your grub configuration, you shouldn't encounter any problems with that. At any rate, it should be fixable via the live session.
geirha
  • 47,279
