I don't think the setting you mention is related.
Trouble-shooting
Error messages relating to suspending are typically found in /var/log/pm-suspend.log so have a look there.
Typical cause
These problems are usually due to some process(es) stopping the system from being suspended.
Do
dmesg -T|grep Freez -A4
and look for these entries:
[sun mar 3 15:19:48 2013] Freezing user space processes ...
[sun mar 3 15:20:08 2013] Freezing of tasks failed after 20.01 seconds (3 tasks refusing to freeze, wq_busy=0):
[sun mar 3 15:20:08 2013] mount.nfs D e8631aa0 0 5518 5517 0x00800004
[sun mar 3 15:20:08 2013] e8631b10 00000086 f7bc0e00 e8631aa0 c1053cb4 c1809020 c192ee00 c192ee00
Check the time stamps to see which of the reported problems relate to your try to suspend. In this case, it is mount.nfs that is causing the problems.
Suggested workaround
Have a script run automatically before suspending and have the script kill the offending process:
The user can provide scripts in the /etc/pm/sleep.d/ directory. Those scripts will be run by the system at suspend and resume. The file name should start with an ordering number. 00-49 is used for user scripts. For details, see man pm-suspend.
The script could look like this:
#!/bin/sh
(killall -9 mount.nfs; exit 0)
...with correpsonding entries for other processes that caused problems, if any.
Parenthesis and exit 0 is a trick: if the process isn't found, killall will exit with en error exit code which will cancel the entire suspend. The parenthesis will make killall run in a sub-shell which will exit with exit code 0, regardless of the killall exit code.
If you're having problems, check /var/log/pm-suspend.log since it will also log problems relating to running the scripts in /etc/pm/sleep.d/.
