Openning a png file in ubuntu, I can see the menu item for 'print to file'. How can I do the same on shell? PS: I prefer installing no extra package, due to lack of root access.
EDIT: the operating system is ubuntu 11.10
convert xyz.png xyz.pdf should do the trick.
See man convert for more options.
As mentioned in a comment below, if you get a security error, you may need to edit the security policy file. For additional details see:
If you want to convert multiple images, e.g. png files, into one single pdf use convert with the specified pdf filename at the end
convert *.png mydoc.pdf
It will merge all png files into a sinlge mydoc.pdf file in a descendant order.
If converting each PNG file to separate PDF files is necessary:
for file in *.png; do convert ${file} ${file:0:-4}.pdf; done
This command takes all PNG files in a directory and produces PDF files with the same name.
